Problem setup of a rigid body
Old   April 16, 2015, 07:21
Question Problem setup of a rigid body
Ahmed Abdel Samad
3absamad is on a distinguished road
Hello everyone,
I'm pretty new to FLUENT however I've some basic knowledge that I had couple of simulations running..
from the key point that a correct problem setup is very important in having accurate results and a converged solution I want couple of help on my problem setup:
first of all I'm simulating a helical micro swimmer with an attached magnet, a full rigid body to be correct in a channel, 3D simulation.
what you should know the helical swimmer is pretty much small, the total length is around 2mm and helix diameter around 0.5 mm.
so my current setup is:
1. The swimmer is defined as a wall inside an enclosure which is pretty big compared to the size of the robot cylinder radius is r = 25 mm and length L = 25 mm,
2. the mesh is pretty much basic here are the details:
1591798 tetrahedral cells, zone 3, binary.
1591798 cell partition ids, zone 3, 4 partitions, binary.
3150278 triangular interior faces, zone 2, binary.
2270 triangular wall faces, zone 1, binary.
63890 triangular wall faces, zone 8, binary.
238 triangular pressure-outlet faces, zone 7, binary.
238 triangular velocity-inlet faces, zone 6, binary.
284959 nodes, binary.
284959 node flags, binary.
3. Pressure based solver
4. I use standard k-epsilon model with default values.
5. Inlet velocity of 1 m/s and gauge pressure of 0 Pa
6. Outlet gauge pressure is also 0 Pa
7. the wall of the robot is specified to be rotating at 5 rad/s (I want to simulate from 5 rad/s till 100 rad/s to plot a graph of rad/s and net moments and forces)
around 400 iterations I reach a converged solution, however at enclosure of 30 mm radius and length of cylinder I didn't get a converged solution message at even 20,000 iterations.
My questions are:
*Is the enclosure/domain okay? or big? should it be smaller? (smaller means lower number of iterations for converged solution message)
*Is the model I'm using okay? or should I use another turbulence model? because it's a low Reynolds number?
*When I say that the wall is rotating, does it move at a certain axial velocity because of propulsive force? or remains stationary? should I define the wall functions using a UDF to specify that the wall is rigid body and allows all 6DOF motion?
Thanks a lot in advance, I'm using the simulation before I go to practical tests as we are working on a research paper.
3absamad is offline   Reply With Quote
Old   April 16, 2015, 23:04
jacky831 is on a distinguished road
can you give us some pictures of model?
jacky831 is offline   Reply With Quote
Old   April 17, 2015, 12:08
Default Here you go!
Ahmed Abdel Samad
if there's anything else that needs clarification, please tell me.
fluent 14 to fluent 15., rigid body, rigid body motion
6-dof rigid body solver AUN CFX 4 October 3, 2017 20:49
Problem with rigid body motion ghost82 EnSight 11 March 12, 2015 10:22
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 05:02
