Courant number alert/pause simulation in fluent 2d
Old   April 15, 2015, 15:50
Default Courant number alert/pause simulation in fluent 2d
arrmando
aarratia is on a distinguished road
Hi Guys,
I am running a simulation in Ansys Fluent, where I have a 2D settling tank for 2 different fluids. When running the simulation, I start with a very small time step size meanwhile using time stepping method "Variable". This method changes the time step to a larger number every interval. My problem is that after a while the Global Courant Number increases overtime to the point where it reaches 250 and Fluent crashes. So I usually babysit the simulation manually pausing it and giving it smaller time steps when needed.
Is there a way to set some type of warning so simulation stops (automatically) before actually crashing?
Best Regards,
Armando
aarratia is offline   Reply With Quote
Old   April 16, 2015, 03:07
`e`
`e` is on a distinguished road
We've had a few recent discussions on how to stop Fluent partway through a simulation using Scheme and UDFs (it's a little messy and probably easier if you avoid this solution pathway). Have a read of those threads if you'd like to try and stop the simulation at a particular maximum Courant number.
Have you tried using a dynamic time step (either through what's available in Fluent already or with a custom UDF time step as a function of Courant number/similar)?
`e` is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
TwoPhaseEulerFoam high courant number mwaqas OpenFOAM Running, Solving & CFD 11 July 11, 2017 15:19
Visualizing mesh regions with high courant number? Endel OpenFOAM 2 August 20, 2013 04:57
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 05:49
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
