Convergent-Divergent nozzle Turbulent Models Problems |
April 11, 2015, 12:24 |
rafik
Rep Power: 15 |
Hello
my case is simulating Convergent-Divergent Nozzle with NPR=4.0 the simulation results of k-e STD turbulent model shows good results compared to the experimental readings. however the problem is that i got bad results for static pressure on the inner surface of the nozzle when using K-w SST and K-e RNG models. as shown in the attached figures. i tried different mesh configurations , also a different Y+ values ( 0.5, 1 , 30 and 200) all have small impact on the results . and results are almost mesh Independence. please i need advice to achieve an acceptable results for K-w SST and k-e RNG. i think the problem is about separation after the minimum area of the nozzle. need advice abut Models corrections , constants corrections or mesh requirements modifications. Thanks For your Help Attached: Pressure Results For Turbulent Models Velocity Mach Number k-e STD Velocity Mach Number k-e RNG |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Convergent Divergent Nozzle | Hrishikesh | Main CFD Forum | 12 | June 25, 2016 03:06 |
Reynolds transport, turbulence model, etc | Beginner | Main CFD Forum | 1 | January 7, 2009 06:36 |
Problems with collision and break up models | Katya | FLUENT | 0 | October 4, 2005 05:00 |
How to active the turbulent models | w0er | FLUENT | 12 | May 18, 2005 13:11 |
