Slow overwriting of parameter values when Fluent is opened
Old   April 10, 2015, 06:18
Default Slow overwriting of parameter values when Fluent is opened
zubs is on a distinguished road
I am running a fluent simulation with about 160 input-parameters. The simulation is controlled by Excel VBA and I need to calculate many cases. At first I tried to run the Workbench Update() command, but the loading and initialization took much longer than the calculation itself.
Now I tried to keep Fluent open and start the simulation with SendCommand(Command="/solve/iterate 1000"). This works pretty well, but when the fluent case is open, the changing of the input-paramter values in workbench takes about 100 seconds. If fluent is closed this only takes about 3 seconds.
So is there a way to keep the fluent simulation open and speed up the overwriting of the input-parameters?
zubs is offline   Reply With Quote
Question about Fluent monitor and input parameter Anna Tian FLUENT 6 March 19, 2015 11:17
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell Fluent UDF and Scheme Programming 2 October 21, 2011 14:12
shear rate values with fluent IƱigo Main CFD Forum 0 October 17, 2005 07:25
Getting values from fluent solver Moshiur R. Chowdhury FLUENT 2 November 27, 2002 14:41
