April 9, 2015, 07:37 |
calculation of Lift problem
Imran Ansari
Rep Power: 12 |
I am working on naca0008 profile. using circular domain of radius 15. i have structured grid of 70400 node points at Re6000 in fluent. my proile drag validate but lift not validate.
i have change my domain to radius 30 but results are about same. quality is also good. i have check at alpha= zero and 4 degree. in both case drag validate but lift not. Solution methods are Prssure velocity coupling Scheme Fractional step Gradient Least square cell based pressure- standard momentum- Quick Second order Implicit-- Non iterative time Advancement Time step size 0.001 Please See my problem and give suggestion about lift as i got lower (less than half of the lift) |
Lift maximization Drag constrained problem. | zkdkeen | SU2 Shape Design | 1 | January 16, 2015 03:46 |
problem in fluent calculation | ENG.HVAC | FLUENT | 0 | November 17, 2013 19:40 |
lift and drag ceofficient problem | icemaniac178 | CFX | 6 | August 17, 2011 19:40 |
lift calculation | shani | FLUENT | 1 | January 28, 2005 04:35 |
how to solve this problem in CFX5 calculation? | cfxbeginer | CFX | 2 | May 1, 2003 09:55 |
