Medical robot simulation
Old   April 9, 2015, 07:11
Post Medical robot simulation
Ahmed Abdel Samad
3absamad is on a distinguished road
Hello Everyone, I'm currently doing my bachelor's degree in Mechatronics and we are having a really tough time in our project.
I am simulating a micro-robot in a fluid flow to be able to understand it's propulsion characteristics throughout the drag forces that occur on this micro-swimmer.
Basically my problem is that I never used ANSYS, and the simulation results are always wrong and not repeatable for different rotational values. let me explain what I have to simulate so you have a good understanding:
a helical micro-robot, a robot which rotates around itself because of outer magnetic field thus from rotating at different RPMs different axial velocities are achieved it's basically like a screw rotation, but in fluid. the shape is very simple a helix attached to a very small cylinder magnet nothing more.
I have the geometry from solid-works, mesh it on ANSYS and setup the problem but I have no idea if it's correct setup or not:
I use the following:
1. K-epsilon model with default values
2. velocity inlet (either 1 or 2 m/s values, gauge pressure 0)
3. pressure outlet with 0 gauge pressure
4. Fluid is glycerin whatever it doesn't really matter
5. I use pressure based solver
and the robot itself is read as a wall, additionally rotates around the (1,0,0) axes with 10 rad/s (at this point I need to simulate different values for rotational speed for a graph plot of the behavior)
I also use a screen monitor for the Drag coefficient.
I specify 1000 iterations but at after 280 it says Solution is converged!
Any idea where did I go wrong? I'm pretty sure in almost everything but I have zero knowledge with ANSYS and I have to have results and valid ones specially I have to publish a paper, also if anyone has recommendation or able to help with problem setup I would be really glad.
3absamad is offline   Reply With Quote
cfd consulting, fluid dynamics, fluid flow, rigid body motion
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
