Pressure has no sense with periodic bc
Old   April 9, 2015, 05:04
Default Pressure has no sense with periodic bc
xab
xabi
xab is on a distinguished road
Hi everyone,
I am simulating the flow through a tooth of an oil pump but I am having some problems when imposing periodic boundary conditions on the inlet and the outlet. The mass flow rate and velocity are normal and similar to the non periodic problem but the pressure contour has no sense
I have simplified my problem making it longitudinal instead of circular and make translational periodicity. The bottom wall has a movement of 2 m/s and 3 bar of pressure drop from inlet to the outlet
I attach some pics of the results I obtain with and without periodic conditions.
With periodic conditions
Without periodic conditions:
Thanks for every help
xab is offline   Reply With Quote
Old   April 15, 2015, 03:21
xab
xabi
Hello again,
I managed to solve it and if there is somebody with the same problem I hope this will help.
The problem is that when setting periodic conditions, the contours of static pressure don't show the pressure gradient introduced at periodic conditions. So if you want to show the contours with the real pressure you need to create a custom field function as p+Δp*x
Hope this is of any help
Xabi
periodic, pressure fail
How to plot pressure drop with Periodic BC? bigfans FLUENT 7 November 8, 2016 12:28
pressure gradient of a 2D periodic flow problem Honey FLUENT 1 October 17, 2012 07:06
pressure gradient of a 2D periodic flow problem Honey FLUENT 0 September 19, 2012 04:21
Periodic pressure gradient monitor in CFX Luke1984 CFX 4 April 5, 2010 15:56
Pressure BCs or Periodic BCs for model of frost on vertical surface? andy.eco FLUENT 2 March 26, 2010 03:02
