March 17, 2018, 04:14 |
#21 |
Hello Alialemana,
I couldn't able to figure out your problem exactly..I just can understand that your problem is not converging... Could you mind sharing your model, preprocessing settings to check it thoroughly... Also try the following, since there are two inlets, first allow flow from one inlet - converge the solution and then permit the flow from second inlet. If not then, reduce the URF values marginally to check it.. Best Regards |
March 19, 2018, 01:09 |
#22 | |
Rep Power: 11 |
Thank you for your reply. I am not able to understand where to patch the rate equation udf inside the porous media section. Can you please help me? Thanks |
May 25, 2018, 02:20 |
#23 | |
Rep Power: 11 |
ArS(l) + H2(g) = Ar(l) + H2S(g) 1. Do I need to define both reactants and products in the species list? 2. How do I segregate between the liquid and gas. Because if I enable mixture template in the species transport model for both gas and liquid then both phases will have all the species components but I need the gas phase to contain only gas species and liquid phase to have only liquid species. I would really be grateful if someone could kindly help me. Thanks |
November 2, 2022, 02:42 |
#24 |
Hi, just to clarify...
I'm simulating the dispersion of cough particles in a mechanically ventilated room using DPM. if i neglect evaporation of the discrete phase, I do not need to enable the species transport right? Is multiphase model required in this case? Thank you in advance. |
Divergence problem for species transport model | MY | FLUENT | 3 | January 11, 2014 05:46 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Species transport : how to model a contrast dye in blood | vix | FLUENT | 0 | August 13, 2013 11:28 |
species transport model or mixture model? | achaokaoyan | Main CFD Forum | 0 | July 10, 2010 11:52 |
need help about species transport model | mengyue1 | FLUENT | 2 | May 18, 2010 23:50 |
