April 7, 2015, 10:16 |
Fluent crashes on Windows 8.1 64 bits
Renato Venturatto Junior
Rep Power: 12 |
Hi there!
I am facing a problem with Fluent when running on Windows 8.1 64 bits. It does not matter the simulation I am running, Fluent might crash at any time. I can not predict either when it is going to happen: sometimes the simulation goes until the end, but in most cases it crashes before tcompleting the calculation. My laptop is new, I believe there aren't any problems regarding hardware. Besides, I am using 15.0 academic version and I have a legal license. Is anyone having a similar problem? I'd appreciate your help! Regards, Renato. |
April 7, 2015, 13:06 |
Rep Power: 13 |
That is Abnormal exit of the fluent. Even I faced this problem earlier. I think its related to ram, I changed Non ECC ram to ECC ram and its working well for me.
April 7, 2015, 15:42 |
#3 | |
Mahdi
Rep Power: 13 |
Hi During the fluent job, monitor the performance or process of system under task manager window to find out if there is a problem with memory, CPU or even hard disk. |
April 7, 2015, 21:37 |
Agung
Rep Power: 11 |
maybe there is something wrong with your hardware. my friend faced the same thing like you until he upgraded his computer RAM. pls show the print screen of your program when it crash.
April 8, 2015, 08:47 |
Rep Power: 12 |
Thank you for the answers!
I don't want to believe there is a problem with my RAM memory. There is no message on Windows when it crashes. It just...closes. I've seen a message once saying something like...this program stopped working. I'll monitor the variables of the system as you reccomended and get back to you! Thanks! |
April 8, 2015, 18:07 |
Rep Power: 18 |
Are you using any UDFs with User-Defined Memory (UDM) calls? I've experienced instant fatal crashes with Fluent when I haven't enabled UDM and it's called from a UDF. Try running a vanilla simulation.
April 9, 2015, 04:45 |
Rep Power: 13 |
Without using udf also fluent crashes. It gives error
"Error [node 999999]" Abnormal exit. |
May 2, 2015, 16:09 |
Rep Power: 12 |
Still facing the problem!
I have some more information for you now. Please find attached the files I have regarding this problem. Apart from the three pictures, I noticed that Fluent creates a *.log file in the working directory. I pasted it below: Error [cortex] [time 5/2/15 1:5:53] C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0\cort ex\win64\cx1500.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error [cortex] [time 5/2/15 13:3:39] C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0\cort ex\win64\cx1500.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. I monitored the system variables as you recommended, and I guess there is no problem at all. I am looking forward for your comments. Thanks! Renato. |
June 14, 2017, 11:57 |
Failure
#9 |
Dawid Berdel
Rep Power: 9 |
Can anyone give anwser to the post above mine. I have similar problem. Ansys Fluent is working for about an hour and then disappears. It is leaving behind error files equal to number of threads that he is working on, displayed in notepad files but only node 0 file has a message inside:
Error [node 0] [time 14.06.2017 12:37:21] Abnormal Exit! and an additional file with number 999999 with same text but coresponding number. |
64 bits, crashing, fluent, windows 8.1 |
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines | ghost82 | FLUENT | 54 | February 9, 2022 03:32 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent on Microsoft Windows Server 2003, possible? | IvanCFD | FLUENT | 0 | February 10, 2011 04:45 |
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) | Mir5 | FLUENT | 3 | April 29, 2009 10:32 |
Fluent 64 bits problem | CFDnewbie | FLUENT | 1 | June 20, 2007 14:06 |
