Velocity weird behaviour
Old   April 1, 2015, 01:45
Default Velocity weird behaviour
Umberto
cinclus is on a distinguished road
hello everyone,
I am simulating the oscillation of a flap in laminar flow.
Time step is 0.01 and I have 20 iterations per time step.
Solution looks compliant with theory (sinusoidal oscillation of cl, cd and cm with cd frequency double cm and cl one)
Once I play the animation though I can see the velocity magnitude in the far field changes abruptly from time step to time step (not every single time step but few times in the whole simulation).
Do you have any idea where this issue originates from?
Mesh looks good and pressure animation doesn't show any visible issue.
Thanks in advance.
cinclus is offline   Reply With Quote
conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result. sharonyue OpenFOAM Running, Solving & CFD 12 April 10, 2016 00:30
Velocity distribution function sampling issue in DSMC flotus1 Main CFD Forum 6 December 13, 2014 07:18
weird velocity profile firavia FLUENT 12 November 9, 2012 07:54
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
