March 30, 2015, 21:12 |
Reattachment Length using fluent
Hassan Iftekhar
Rep Power: 11 |
I am trying to model a flow over a step. Reattachment length found using Experimental studies is 13.8 mm. I have tried generating fine mesh around step and found reattachment length of 15 mm. I am trying still to go close to this value around 14.4 mm. How can I get exact reattachment length using fluent. Do I need to change any model constants to get exact reattachment length. Earlier I have used default model constants. My flow is turbulent. Inlet velocity is 0.5 m/s and It is rectangular duct. More over it is adverse pressure gradient. Should you need more information kindly contact me Thanks Hassan |
March 30, 2015, 21:24 |
Hassan Iftekhar
Rep Power: 11 |
I am using 5% turbulent intensity and 6 mm turbulent length scale. and intermittency of 1 for my study at the inlet and outlet. I am using transition SST model.
I already have studied the effect of increasing and decreasing the length scales and turbulent intensities. |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 20:12 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
Wake Length calculation in FLUENT | mahi007 | FLUENT | 2 | March 14, 2012 05:51 |
the reattachment length of rearward facing step | Tom,L. | Main CFD Forum | 4 | December 14, 2002 05:24 |
