MSMD battery model
Old   March 30, 2015, 11:28
Default MSMD battery model
Haroon Junaidi
Topgun79 is on a distinguished road
I am starting modelling Li-ions battery pack in Fluent. Although there is some information inside the documentation but I was keen on getting step by step tutorials for MSMD battery model.
I do not know how to setup the batteries properly. Any help would be most appreciated.
Topgun79 is offline   Reply With Quote
Old   November 21, 2020, 02:54
Ajay Tyagi is on a distinguished road
hey,
I am having a problem running the simulation for the battery pack in the ECM model.
It is IDA error and temperature limited error.
Any help will be appriciated.
Also, the HPPC test done for a single cell can be applied to the battery pack?
Ajay Tyagi is offline   Reply With Quote
Old   November 23, 2020, 02:03
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
there are too many things, which could lead to this error.
you should describe in details if you going to get help
HPPC test can be used to tune electro-chemical model parameters
of course it is data from single cell. Same ecm model is applied for batteries in modules
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 23, 2020, 02:06
Thanks for your reply
Old   November 23, 2020, 02:12
I have tried to run simulation for battery pack (51.2 V, 100 Ah) with default coefficient in NTGK, ECM module. First I want to run with default coeff then later will try for HPPC test coefficient.
But it is not happening. With NTGK model, simulation is running up to some iteration but after 200 sec it damages abruptly. And the temperature limited error is coming.
And with ECM model, only after 2 iteration, the "divergence detected in AMG solver" error is coming. Not able to run the simulation. I have tried everything, don't know what is missing.
Old   November 23, 2020, 07:35
Alexander
if you are using default parameters, then (most likely) you have problems with your mesh and/or boundary conditions.
on the other hand, for battery module basbars must be prepared in a special way, so when you are clicking "print battery system connection information" in console you may see all zones are defined in proper way
also use small timesteps for first few iterations
best regards
battery pack, lithium ion, msmd
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 11:23
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 10:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
