March 27, 2015, 07:05 |
Energy Prandtl Number
kiarash kiani
Rep Power: 11 |
Dear experts, Recently I am working with RSM for modeling turbulent heat transfer. Although, the model correctly captures the hydrodynamics, energy prandtl number should be modified as a function of some geometric parameters (Distance to nearest wall,...) and flow variables (Turbulent Kinetic Energy,...). Unfortunately I could not find any option in, model> viscous> Reynolds Stress, to modify "Energy Prandtl number" with UDF. Energy Prandtl number modification is only available for K-epsilon. I will appreciate someone could help me handle this problem.
March 29, 2015, 09:29 |
Lucky
Rep Power: 66 |
try /define/model/viscous user-defined
It is the same for all models |
March 29, 2015, 13:32 |
kiarash kiani
Rep Power: 11 |
thanks, but there is a problem
If you select RSM in Viscous>Model then user-Defined is not visible in TUI. |
March 29, 2015, 13:59 |
Lucky
Rep Power: 66 |
works for me. did you forget to turn on the energy equation?
March 29, 2015, 14:17 |
kiarash kiani
Rep Power: 11 |
Dear sir,
I did these: 1- energy equation is On. 2- From GUI, Define>Model>Viscous>Reynolds Stress 3- In TUI, define>Models>viscous> and user-defined is not visible If I select for example Realizable k-e, then user-defined is visible under turbulence-expert in TUI. |
September 11, 2020, 06:56 |
#6 | |
Rep Power: 6 |
You solved this? I met the same problem for my udf implementation. Thanks, Bryce |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 16:05 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 07:39 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
