Amin
Rep Power: 14 ![]() |
Hi friends
Is there any way to calculating Stokes number for a 2 phase flow in a duct? Does fluent calculates this number? Can we use fluent results for it? |
S. Morichika
Rep Power: 12 ![]() |
Did you get anything regarding stokes number? I am also using FLUENT and if possible, I want to do something related stokes number.
Thanks anyway. saeed |
Cees Haringa
Rep Power: 0 ![]() |
Are you using DPM multiphase or Eulerian multiphase? As far as I know FLUENT does not calculate the stokes number directly (but if you have a certain drag law it does calculate many of the parameters in there to determine drag). It's easy to determine via UDF though. If you have DPM, I'd use DPM-scalar-update to calculate the stokes number and write it to a DPM scalar, such that you can extract the number for every particle at any snapshot of time. If you are using Eulerian multiphase with a single bubble/particle size, you can use define_execute_at_end to calculate it for each grid cell, and store in the UDM. Of course there is a problem if you use a population balance; then you need to base it on the mean diameter or so, but of course there will be a distribution in stokes number there. |
Amin
I think fluent cannot report Stokes number directly,
but as Cess said, there are several advance ways to computing Stokes number, and the simplest way is using simplified equation of Stokes number: Stokes= [(dispersed phase density )*(career phase velocity)*(particle diameter)^2]/ [18*(dynamic viscosity of career phase)*(characteristic length)] it's a simple way and has a some errors but it's good for start! |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries | vkrastev | OpenFOAM Pre-Processing | 7 | June 2, 2016 15:50 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
