March 21, 2015, 05:30 |
Plot output parameter’s oscillation
Pierre
Rep Power: 11 |
When I model cases with boundary layer separation, the output parameters always oscillate with iterations. That is normal and usually can’t be avoided easily. When I run a large number of simulations automatically, the simulations just can be set to run all automatically and only output parameters values without oscillation information can be given and listed automatically as well. But in this case, I won’t know whether oscillations happen in any of the simulations I just run and how strong the numerical oscillations are.
I once used Numeca Fine Turbo to do turbomachinery simulations. It could plot the oscillations of each design point automatically which brings huge convenience. I’m wondering could CFX or Fluent also do that? |
March 22, 2015, 20:55 |
Lucky
Rep Power: 66 |
Create some monitors for your output parameter. Plot or print to file as you like.
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 13:08 |
[swak4Foam] Foam warnings - related to swak4Foam | Salam-H | OpenFOAM Community Contributions | 20 | August 2, 2015 16:40 |
new variable output as a file in openfoam for Ensight plot | conceptone | OpenFOAM Post-Processing | 1 | February 18, 2014 15:54 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
Macro to output a plot curve | E Fardream | Fidelity CFD | 5 | July 9, 2007 09:13 |
