Setting up additional convergence criteria: output parameters are ‘constant’ |
March 21, 2015, 03:49 |
Pierre
Rep Power: 11 |
Typically there are two convergence criteria
1. Residuals drop to enough low value 2. Output parameters (the parameters we care about in the simulations results) don’t change anymore with more simulation iterations It seems that we can only set up the 1st criteria in Fluent and CFX. Regarding the second one, we need to either monitor by eyes or setup to run absolutely enough iterations number to make sure the simulations satisfy it. Both of these two ways are costly. Anyone has a better way to set up the second criteria? |
March 21, 2015, 08:01 |
Rep Power: 18 |
You could use a scheme file alongside your UDF as described on this page (first Google search result..).
March 22, 2015, 20:44 |
Lucky
Rep Power: 66 |
After you have created your monitors (surface monitors or volume monitors) you can then specify convergence monitors. This will allow you to specify absolute convergence criteria to any existing monitors. In the GUI, the convergence monitors are on the monitors panel at the bottom, below surface and volume monitors.
March 23, 2015, 10:47 |
Andrew Kokemoor
Rep Power: 14 |
Fluent User's Guide Section 28.16 goes over the convergence manager. This was added in either 14.0 or 14.5, so you might not have it if you're using an older version.
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Additional variable as output of an expression | Chander | CFX | 1 | November 22, 2011 13:54 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
[CFX] Set convergence level for additional variable | Lance | CFX | 1 | December 15, 2010 08:22 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
