Simple Flow Problem
Like Tree1Likes
Old   March 18, 2015, 12:16
Shailesh
prwl120 is on a distinguished road
Actually boundary condition are assumed. But situation is practical.
Its Ball bearing, i am studying the pressure variation on lubricant between Balls and bearing wall.
So what should you suggest i would do, decrease the velocity or increase the pressure.
prwl120 is offline   Reply With Quote
Old   March 18, 2015, 12:31
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Your simulation cannot be real with that boundary condition.
What do you want to study?
What results can you expect if you set assumed boundary conditions?
Fluent is a solver and you should expect divergence if you set wrong boundary conditions!
You cannot ask us what boundary conditions to set, it depends on your application and you must know your boundary conditions to simulate your domain.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   March 18, 2015, 13:04
Shailesh
Thanks for your help...
But which condition i must have to remember while solving the question.... like is there any upper or lower limit of pressure or velocity in FLUENT.
One more question : is it ok if my mesh quality is just above 0 like 0.003. Or i have to work on my mesh too. I know low mesh quality will bring poor solution but does it also bring divergence in solution???
And does Fluent only accept unstructured mesh??? and what will happen if i provide it a structured mesh???
Old   March 18, 2015, 13:18
ghost82's Avatar
Rick
As I know there are no limits, apart that you set in solve->controls->limits.
However, I repeat, that if you set wrong (non physical) boundary conditions, fluent will probably diverge.
In your case, with your boundary conditions, the pressure at inlet should be near 500000 atm and velocity at the restriction near 10000 m/s.
These values are both not physical.
If you just want to do a test, set a velocity at the restriction between 25-30 m/s, so to have an inlet velocity of about 0,0025 m/s.
You should enable cavitation model also, otherwise you will have negative absolute pressure at the restriction, which, again, is not physical.
I don't know how fluent reports quality of mesh: usually I evaluate different parameters directly in preprocessing.
Low quality meshes can cause not accurate results, difficult in converging and divergence.
As far as I know hexa meshes are better than tetra, however in some cases (complex geometries) tetra mesh is the only choice.
Old   March 19, 2015, 00:16
Shailesh
How do i enable cavitation model. Sorry if i am silly to ask this but i am new to ANSYS.
And Thanks for all the help so far.
Old   March 19, 2015, 09:03
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
Just to be clear: Structured vs unstructured mesh deals with the way each element is named and ordered within the domain. like muthu said before just convert your premesh to unstructured mesh while in ICEM and you can easily import your hexa ("structured" appearance but technically unstructured) mesh into fluent you will no loss of quality. .003 quality is really bad.
ghost82 likes this.
edoan is offline   Reply With Quote
Old   July 29, 2016, 08:10
Guruprasath S
Guruprasath S is on a distinguished road
hai all..i am solving turbulance model sst k-omega with MRF method for blower.my problem is reversed flow in pressure outlets and during hybrid initialization pressure information is not available at boundaries.
If i am giving inlet velocity values,reversed flow occur and divergence happend...
How can i solve this problem and how can i fix this issues...and how can i achive convergence.....please help me
Guruprasath S is offline   Reply With Quote
ansys, ansys 14, fluent, fluent 14
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 01:42
Problem with changing mass flow rate roo FLUENT 3 June 4, 2013 15:53
Problem of mass conservation in multispecies flow in porous media and T° gradient pilou FLUENT 0 January 31, 2011 09:19
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
