Problem with conjugate heat transfer in Fluent
Old   March 16, 2015, 09:17
Question Problem with conjugate heat transfer in Fluent
谭健
JianT88 is on a distinguished road
Hi all,
I'm working on a case with conjugate heat transfer using pressure coupled pseudo transient as solution control. My case contains four cell zones: two fluid zones (1 stationary & 1 rotational frame, incompressible ideal gas) and two solid zones(one of them has a heat source, solid is aluminum and piece-wise temperature depended heat capacity). I'm running a steady state simulation and meanwhile monitoring specific surfaces to check if the heat transfer has reached steady state. All relevant surfaces have coupled/via system coupling as thermo boundary condition.
My question is a problem I've observed: sometimes, in one case, the temperature(monitored) increases pretty fast (around 20 deg for one iteration), sometimes it increases extremely slow (about 0.1 deg for one iteration), and both are running under the same case file so I don't think there's any differences of the settings. A very slow temperature increase will result to a much more computational cost.
I'm not using any UDFs, it is a quite straight-forward model. I wonder if you guys has seen similar cases and have any ideas what is really happening behind this? Thanks!
Best Regards,
Jian
JianT88 is offline   Reply With Quote
heat transfer balance, heat transfer convergence, heat transfer modelling
Conjugate heat transfer problem troyker FLUENT 1 March 22, 2014 14:46
Conjugate heat transfer problem Engineer4 FLUENT 0 May 5, 2013 22:14
Conjugate Heat Transfer Problem vasava FLUENT 3 January 11, 2013 02:52
Hypersonic conjugate heat transfer problem carnage2121 FLUENT 0 June 4, 2011 19:08
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
