Nitrogen as a real gas
Old   March 15, 2015, 23:12
Smile Nitrogen as a real gas
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi everyone,
I am interested to simulate nitrogen passing through JT (joule Thomson) valve by considering nitrogen as a real gas (Isenthalpic Expansion). can you please suggest me any ANSYS Fluent tutorials on Real gas.
sunilpatil is offline   Reply With Quote
Old   April 11, 2016, 23:51
sunilpatil's Avatar
sunil
Hi I found out the way by considering nist real gas in fluent we can solve this problem
Regards,
Sunil
Old   April 12, 2016, 09:27
Lucky
Just a comment. You don't need a real gas to simulate an isenthalpic expansion. But you can do a real gas using NIST.
Old   April 12, 2016, 09:51
sunilpatil's Avatar
sunil
Hi joule Thomson expansion is isenthalpic and that can be captured by considering real gas as working fluid. Please correct me I am wrong.
Regards,
Sunil
Old   April 12, 2016, 10:07
Lucky
Joule Thompson expansion is really just an adiabatic expansion. That is a thermodynamic process from State A to State B. That is independent of the substance or the equation of state of the substance. Any substance can undergo an isenthalpic expansion. The J-T effect is a phenomenon that specifically occurs for a real gas and real substances (which has non-zero J-T coefficient). An ideal gas, by virtue of its definition has J-T coefficient = 0.
If you are simulating J-T effect, then you need to use real gas. But simulating an isenthalpic process is a different problem.
joule-thomson effects, realgas
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Nitrogen as a Real gas sunilpatil CFX 0 March 15, 2015 23:11
Problems in air flow udf - divergence PJT Fluent UDF and Scheme Programming 0 May 28, 2013 11:01
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
