Solution initialization in case of couette flow |
March 15, 2015, 09:49 |
Ashutosh
Rep Power: 13 |
I am modeling 2d couette flow in fluent. The upper plate moves at 5m/s. When I go in solution initialization I select compute from as top plate. I expect that the intitial value should be taken as 5m/s. But the initial value still remains at 0m/s. In case of flow over a flat plate when compute from inlet is give the initial value is taken as the value of velocity at inlet as specified in boundary condition. Why doesn't this happen during couette flow? |
couette flow, flat plate, solution initialization |
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle | cdm | OpenFOAM Running, Solving & CFD | 7 | August 28, 2019 02:37 |
LES: Turbulent Channel Flow without initial solution (BC) | DaSh | OpenFOAM Running, Solving & CFD | 21 | February 8, 2015 17:09 |
Setting up a case for a plane plate in a longitudinal flow | Chronique | OpenFOAM Running, Solving & CFD | 0 | October 9, 2014 15:17 |
solving a case on flow through duct | hariya03 | OpenFOAM Running, Solving & CFD | 0 | August 10, 2013 17:30 |
Numerical error or case error? Flow in a 3D pipe | fsalvucci | OpenFOAM | 40 | January 30, 2013 08:10 |
