Heat Flux and Radiation at same boundary
Old   March 11, 2015, 15:20
Default Heat Flux and Radiation at same boundary
Mario Arias
MarioArias is on a distinguished road
I am trying to model a heat flux boundary condition on a surface, and would like to allow it to radiate into a vacuum. Is P-1 the correct radiation module?And if so, Do i just change the emissivity to a gray body where i want it to radiate, and 0 to any i want shielded in the boundary conditions?
Thanks,
Mario Arias
MarioArias is offline   Reply With Quote
Old   March 12, 2015, 09:56
Paritosh Vasava
vasava will become famous soon enough
I did not understand what you mean by 'shielded'. Anyways with P1-model you will only have emissivity (for radiations) in the boundary setup. 'External Emissivity' for walls and 'Internal emissivity' for walls shared by the interfaces.
The choice of model would depend upon optical thickness. P-1 is good for optical thickness larger than 1. DO and DTRM do not have any such limitations and are more widely applicable. Also with DO you will have more choices over boundary conditions as you can also have semi-transparent material (e.g. glass) in the simulation.
P.S: I too have started learning about radiation since last week. My answer is based on my very brief experience with simulating radiations with fluent.
vasava is offline   Reply With Quote
Old   March 13, 2015, 05:47
Mario Arias
All I have is a square microchannel heat exchanger. I am set a heat flux boundary condition on a single wall of that heat exchanger, and I would like to let it radiate to a vacuum.
fluent parallel memory, heat flux, p-1, radiation, radiation flux
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
