Negative absolute pressure in core vortex
Old   March 11, 2015, 05:58
Default Negative absolute pressure in core vortex
clod is on a distinguished road
Hi everybody,
I'm trying to simulate the internal flow field of a pressure swirl atomizer. I set up a transient VOF simulation to track the liquid interface coming from the feeding line, and then injected into a chamber where air is present at atmospheric condition. In the middle of atomizer, in correspondence of the vortex core, I expected a low value of the pressure (lower than the out pressure), due to the high swirl velocity, but I found a negative absolute pressure (around -16 bar), that does not lead the liquid to open after the injection (as expected from the experiments for the bc under investigation).
I attached the screenshot of the pressure contour where this problem is showed: I set in Fluent the pressure operating condition equals to 0, so the pressure shown in this picture is the absolute one.
The simulation that I set up is transient and incompressible. As input I set the total pressure coming from the experiments (11 bar), and at the outlet I set the ambient pressure (1 bar). The RSM turbulence model has been set.
I used the SIMPLE algorithm with PRESTO! method to define the pressure.
The grid that I created is composed by only hexahedral elements in that region, with 179 cells along the diameter in throat section.
How can I fix the problem of the negative pressure? Can someone help me?
clod is offline   Reply With Quote
Old   March 11, 2015, 06:33
ghost82's Avatar
Rick
ghost82 will become famous soon enough
it should be related to cavitation of liquid; I think that by enabling one of the cavitational model you will solve the negative pressure issue.
However, none of the cavitational model is compatible with the explicit VOF scheme!
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
negative absolute pressure ahmadi FLUENT 0 May 23, 2014 09:54
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
is the contours of absolute pressure will be negative...? nareshnkk FLUENT 3 December 9, 2010 02:13
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
negative pressure mAx FLUENT 0 January 25, 2006 15:31
