March 10, 2015, 16:32 |
regarding divergence
barath
Rep Power: 11 |
Hey I am doing CFD analysis of thermostat valve in ANSYS FLUENT . my pipe OD is 53mm . my Reynolds number is around 200000 . so my flow has a high turbulence. My fluent is water. Water temperature is 90 deg celcius. I ve incorporated the properties in materials database
Setup: No energy equation. I use velocity inlet c=1.16m/s.pressure outlet. Realisable ke model. When I solve this I m getting an error in epsilon . can anyone help me out?? Thank you |
divergence, fluent |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 06:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
