Coefficient of lift on a tidal turbine blade
Old   March 9, 2015, 08:41
Default Coefficient of lift on a tidal turbine blade
stokesy is on a distinguished road
Hi I'm struggling to find the coefficient of lift on the airfoil im simulating in underwater conditions. The only change I can see to make is the density of water surrounding the airfoil but when changing this, this makes the output coefficient off by this factor. Is this correct? I can't believe it is, and struggling for accurate results. Any help would be appreciated.
Thanks
stokesy is offline   Reply With Quote
airfoil 2d, airfoil analysis, coefficient of lift, fluent 14 to fluent 15.
Problemwith lift coefficient - tidal turbine stokesy FLUENT 2 March 6, 2015 04:54
increase the lift force for wind turbine blade dipaksutradhar OpenFOAM Running, Solving & CFD 0 January 28, 2015 16:14
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Lift coefficient Plot for turbine blade- Reg Mahendran.M FLUENT 2 June 19, 2006 23:43
