mixing plane causes fatal error
Old   March 8, 2015, 05:26
Default mixing plane causes fatal error
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi everyone!
I received famous and obnoxious fatal error!!
(FLUENT received fatal signal)
I found out it happens because I use a mixing plane at an axial location! it solved when change "mixing plane geometry" to radial! but my geometry need an axial mixing plane! unfortunately all of my efforts were useless!
so did anybody experience fatal error with this reason!? Is there any solution?
Thanks in advance!
amin.z is offline   Reply With Quote
Old   October 27, 2023, 08:14
Default zero angular velocity on stator
Alan
PacMan is on a distinguished road
Maybe I'm a bit too late...
but
to work with legacy mixing plane, you have to define angular velocity on both rotor and stator fluid zone... the interface where the fluid is mainly exiting its own domain, should be a pressure outlet, while the other one, where is entering, should be some inlet bc (like pressure-inlet, mass-flow-inlet or velocity-inlet)
PacMan is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
