High pressure tank discharge
Old   March 5, 2015, 16:05
Default High pressure tank discharge
hernan
tesorieri is on a distinguished road
Dear all,
I'm modelling the discharge of a high pressure tank to the atmosphere. The tank is very long, has 5mm diamater and is suddenly opened to atmosphere. I've already made some tests with an experimental unit at 70 bar and now I'm modelling it in Fuent ussing an axisymmetric model, with density based solver.
I'm having lots of trouble with the timestep as the solution blows up for timestep sizes bigger than 1e-6s. With this timestep, the simulation takes too long.
Does anybody has any idea on how to increase timestep size?
Thanks!
tesorieri is offline   Reply With Quote
Old   March 23, 2021, 02:19
Default Did you find the answer?
h1773's Avatar
Time
h1773 is on a distinguished road
If you found the answer please update it on the feed.
h1773 is offline   Reply With Quote
Old   March 23, 2021, 05:27
moh
tahar is on a distinguished road
I think the time step is calculated using CFL condition . with 70 bar, the flow has a very high velocity and you are not able to increase timestep size
and why you modelling the full discharge????
tahar is offline   Reply With Quote
compressible flow, discharge, timestep size, transient flow
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Unusually high pressure at only one face kingmaker OpenFOAM Running, Solving & CFD 1 September 13, 2013 03:22
chtMultiRegionFoam solver application for high velocity& High Pressure xiaoyoyo OpenFOAM 2 July 25, 2013 12:50
tank sloshing - getting wrong pressure enghamed CFX 2 April 26, 2011 23:09
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 08:54
