How to set as input parameter in Fluent a variable existing outside it?
Old   March 3, 2015, 11:25
Default How to set as input parameter in Fluent a variable existing outside it?
Adrien
didimad is on a distinguished road
Hy everyone,
I'm trying to couple some output of a Matlab code with Fluent. Let me explain myself : i'd like to set as input parameter for the Fluent solver, a variable ( scalar) that come from matlab code. Is there any way to impose the location (path) of my variable ( saved from the matlab code) in the parameter set, so that i don't have to enter its value manually?
For example, i've a variable named a.txt , and i want to set it as an input parameter through the parameter set interface, how can i do?
Thanks for your help !
didimad is offline   Reply With Quote
Old   March 3, 2015, 12:10
Andrew Kokemoor
Kokemoor is on a distinguished road
Hm, hopefully someone else here can cook up something more elegant, but this should do the trick.
Is there a reason you need to use Fluent parameters in particular? It will probably be easiest to do this with a scheme variable. Here's some unsanitary code that defines a variable "param" and reads the first value in "a.txt" into it.
(rp-var-define 'param 0.0 'real #f)
(define p (open-input-file "a.txt"))
(rpsetvar 'param (read p))
(close-input-port p)
Now that you've got a scheme variable with your value, you can use it pretty much anywhere.
(rpgetvar 'param)
Kokemoor is offline   Reply With Quote
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
Fluent 14 journal script to set fluid parameters jhome ANSYS 0 April 30, 2012 05:26
Error when input new parameter in Fluent micro11sl FLUENT 0 July 1, 2011 07:42
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 03:24
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 06:45
