DQMOM multiphase limitation in Fluent
Old   February 23, 2015, 06:54
Default DQMOM multiphase limitation in Fluent
pannsave
pannsave is on a distinguished road
Hi All,
I was just wondering whether I can do multiphase simulation using DQMOM for three particle size distributions (3 phases) along with 2 phases. It shows totally five phases. I am not sure whether the recent version of fluent has the capability of handling more than 4 phases. Could anyone please advice me. Even I was trying to setup the model, It shows the error message of
PB' s Sauter_d: case not handled.
So i was just wondering whether something is wrong with model setup or fluent multiphase limitation for DQMOM.
Thanks
Regards
Pannsave
pannsave is offline   Reply With Quote
Old   February 23, 2015, 09:35
Paritosh Vasava
vasava will become famous soon enough
What version of fluent do you have?
vasava is offline   Reply With Quote
Old   February 23, 2015, 09:41
pannsave
Our institution has both 14.0 and 15.0 version
Old   February 23, 2015, 10:04
Paritosh Vasava
If I am not wrong there is a limitation especially if you are using the discrete setup. You can have bins for only one secondary phase. However if you switch to the inhomogeneous setup you can have bins for more than one secondary phases.
I am no expert with the population balance but hope this helps.
Old   February 23, 2015, 10:31
pannsave
Dear Vasava,
Thanks for reply. I am using Eulerian with population balance model. I think I may not able to use the option that you have mentioned. Is that correct.
Regards
Pannsave
Old   February 24, 2015, 02:23
Paritosh Vasava
I think you can use all the options with Eulerian multiphase setup.
Old   February 24, 2015, 06:15
pannsave
Dear Vasava,
I would be grateful to you if you could the explain to me in detail about setup.
Mean time, I have checked DQMOM restriction in fluent manual. It is mentioned that "The DQMOM method is restricted to a four-phase system, of which three secondary phases are directly involved in the DQMOM computation".
It seems it is difficult to setup the model.
Actually in my problem, I have sand, fluidisation gas and biomass (DQMOM phase- 3 sizes), so totally 5 phases. I am still wondering to implement this problem in fluent.
I would be grateful to you if you could explain the model setup
Thanks in advance
Regards
Pannsave
Old   February 25, 2015, 03:16
hyunkwonlee
bradlee is on a distinguished road
Is there anyone who know to set up the initial moments?
Somebody help me!!
bradlee is offline   Reply With Quote
Old   July 27, 2017, 11:26
Default Dqmom
Gujun
Gujun is on a distinguished road
Originally Posted by pannsave View Post
Dear Vasava,
Thanks in advance
Regards
Pannsave
Dear pannsave,
I am writing to ask you if the DQMOM can be used to deal with the 5-phases?
Thank you.
Gujun is offline   Reply With Quote
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 13:01
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Multiphase modelling using Fluent VOF sanit FLUENT 0 November 5, 2013 17:00
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
How do I obtain Void fraction from FLUENT Multiphase CFD Simulation? Greatness Fluent Multiphase 0 September 3, 2013 06:02
