Convergence of High Speed Turbulent flows
Old   February 21, 2015, 04:23
Post Convergence of High Speed Turbulent flows
Sathya Narayanan
satty_00 is on a distinguished road
Greetings everyone,
I'm simulating high speed turbulent flow around an airfoil (cascade). I had started with low speeds (40 m/s) and got the results. But now I'm simulating transonic flows 90 m/s and I'm unable to converge the solution. The cascade has a nozzle section where the flow reaches very high velocities.
Settings and Conditions:
Density based Steady state solver.
Working fluid: Air (Compressible flow - Ideal gas)
Turbulence model: K-omega with SST.
Velocity Inlet at 90 m/s ( components at 48 degree )
Pressure outlet at 0 guage pressure
Periodic boundaries on either side of the airfoil (Created using mesh-interface)
Solver Settings:
Courant no: 3
URF for Turbulent viscosity and Disspation rate: 0.5
Other default settings.
Are there anything else to be considered while simulating high speed turbulent, compressible flows ?
I read threads on altering the Operating condtions. I haven't tried that.
satty_00 is offline   Reply With Quote
flow with high turbulent viscosity ratio Phillips Main CFD Forum 2 August 25, 2008 19:01
flow with high turbulent viscosity ratio Phillips FLUENT 0 August 24, 2008 19:01
High turbulent viscosity, problem with BC Narmin FLUENT 2 May 8, 2007 04:17
time step for turbulent flows vishnu FLUENT 0 December 13, 2006 02:28
CFD of turbulent flows raj calay Main CFD Forum 23 April 23, 1999 06:03
