Wind turbine torque calculation is less than expected |
Ahmed
Rep Power: 0 ![]() |
Hi !! help is needed
I am simulating a HAWT but the tesults seems to deviate from the experimental results ( Torque and drag are the main focus of my study) The case is as follows Velocity inlet, Pressure outlet the control volume consists of three zones upper-stream, Moving Zone and Down-stream V=-10 m/s in the x direction Moving Zone is MRF around x axis X=1 , Y=0, Z=0 and w= -133 rad/s which corresponds to the optimum tip speed ratio of 6. turbine blade wall moving 0 rad/s with relative to adjacent zone CFD algorithm SIMPLE (default option) Turbulent model K-epsilon standard near wall function Interpolating scheme for the first 10 iteration 1st order upwind were used then for 1000 iteration followed 2nd order were used Pressure (Standard) Density (Second Order Upwind) Momentum (Second Order Upwind) Modified Turbulent Viscosity (Second Order Upwind) can anyone tells me why the torque value is very low its 13 N.M while in real case its around 85 N.M |
Ahmed
I did something that seems to enhance the torque but it is still lower than expected what i did is as described in the thread (Impact of pressure on the blades with MRF?) @maverick90 which i recommend you to read its very helpful i the case as @ghost82 stated to set the walls of the zones as absolute with 0 rad/s but he also stated to take into account the boundary condition at the inlet which i think is the problem here because when i set the velocity to be normal to boundary condition it gives me components value in all direction in x, y, z
that`s why i choose the velocity in absolute in x-components to be 10 m/sec i don`t whats wrong but when i computed the maximum velocity from the gradient and it reached only 3.6 m/sec. can anyone tells me what to do to solve this problem. |
case set-up, drag force, hawt wind turbine, mrf. moving wall, torque |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
how to find wind turbine torque from CFD ? | siripon | Main CFD Forum | 1 | August 27, 2012 00:41 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
