Compile udf and load libudf library
Old   February 17, 2015, 13:11
Exclamation Compile udf and load libudf library
Francesca Guardavaccaro
starlight is on a distinguished road
Hello everyone,
this is the first time I write/ask something here and I hope my question won't seem too boring and/or "stupid"!
I am a student and I have to solve a flux in a conduct with a Poiseuille velocity inlet profile: I can do that through an udf and when I try to compile it and then load the library Fluent 6.3 tells me this:
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
Error: open_udf_library: The system cannot find the file specified.
I've found people who ask for help for my same problem and I tried all day long to do the things that someone said to them to fix this but I did not have success at all!!!
Could someone help me, please?
(I have a 32 bit notebook and I work with Fluent only, not with the whole ANSYS package).
starlight is offline   Reply With Quote
Old   February 18, 2015, 06:55
fanch33 is on a distinguished road
I had the same problem. I think it's because you don't have any C compiler on your computer.
Use the function interpreted, it should work and for simple UDF it's as fast an function compiled.
Good luck
Fanch
fanch33 is offline   Reply With Quote
Old   February 18, 2015, 08:45
Thank you for the answer! Unfortunately I have already tried the function interpreted but the problem still exists!
Old   February 18, 2015, 08:49
It's strange.
Is the error the same with the interpreted function ?
Old   February 18, 2015, 10:19
Yes! It's the same error!
Old   February 19, 2015, 10:49
manalis is on a distinguished road
Check your installation path of Fluent to see if you have "cpp.exe" file. It should be located in "C:\Program Files\fluent\ntbin\..." or something like that.
manalis is offline   Reply With Quote
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the gxu2 Fluent UDF and Scheme Programming 13 August 10, 2018 18:38
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Error: The UDF library you are trying to load is not compiled for 3ddp on the current Whitemast Fluent UDF and Scheme Programming 0 November 21, 2013 07:45
cannot load UDF library jayilosa Fluent UDF and Scheme Programming 3 November 16, 2011 13:44
help on UDF compile and load Sherry FLUENT 5 October 29, 2005 12:37
