February 17, 2015, 13:00 |
Unable to get quick results withi LES
It may be due to lack of computational resources, but as you know higher management demands results not excuses so I want my results in no time. I am running LES since 4 months and after 1 month it has simulated 1milli sec phenomenon. I am simulating cylinder of 2 m with gas flow and at high pressure of 30 bar. The time step size have to be kept small that is 1e-06 sec and it is due to instability at larger time step size. I need a shortcut in using LES. Computer is z800 with 8 cores (hyper threading makes 16 cores) and 64 GB ram. I need to finish it in 2 months as it is job problem. I need to simulate up to 1 sec physical time. Please suggest quick solution. Regards, |
February 18, 2015, 06:27 |
Cees Haringa
I'm sorry, but life has no shortcuts.
If you already know that larger timesteps cause instability, then you're stuck with it. How big is your mesh size; can you reduce on spatial discretization without missing out on the scales of turbulence you want to resolve? If there is no space there too, well, this is probably the simulation you have to live with. However, 1000 timesteps in 1 month does sound steep. Can you optimize the mesh partitioning such that the communication load between cores is lower (Although on a shared-memory machine, I doubt this would be a large bottleneck) |
February 18, 2015, 06:51 |
Rick
Rep Power: 27 |
I totally agree. You can improve a bit your speed by disabling the hyperthreading in the bios.
Google is your friend and the same for the search button! |
February 18, 2015, 12:34 |
#4 | |
Thanks Ceesh, I should have mentioned the mesh size before. It is 3 million cells. I am running on default 16 cores which are shared. I have enabled hyperthreading. "1000 timesteps in 1 mnth sound steep" what do you mean? Are you appreciating it or its not something good progress? |
doubt about DNS and LES of combustion | chinthakindi | Main CFD Forum | 5 | August 17, 2013 12:56 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 23:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 12:35 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 10:58 |
RANS results for LES | Li Yang | Main CFD Forum | 5 | June 17, 2002 06:34 |
