Analysis of a Model Aircraft
Old   February 17, 2015, 11:38
Default Analysis of a Model Aircraft
Fergus
GusRus is on a distinguished road
Hi.
Newbie post. My project involves a CFD analysis of a model aircraft. I have generated the model in SolidWorks by using 3 view drawings and have been able to import the geometry into Fluent and then created a box in ANSYS geometry editor and berformed the boolean operations. For an idea of size the model of the aircraft has about a 200mm wingspan and the enclosure box representing the wind tunnel is 460mmX460mm square. I am currently having problems generating a mesh in the model. Below are my current settings.
Physics Preference: CFD
Solver Preference: Fluent
Relevance:0
Sizing
Use Advanced Size Function: On:Proximity
Relevance Center: Coarse
Initial Size Seed: Active Assembly
Smoothing: Medium
Transition: Slow
Span Angle Center: Medium
Proximity Accuracy:0
Num Cells Across Gap: Default (0)
Proximity Min Size: 2mm
Max Face Size: 5mm
Max Size: 10mm
Growth Rate: Default
Minimum Edge Length 1.7556e-002 mm
Inflation
Use Automatic Inflation: All Faces In Chosen Named Selection
Named Selection: Bugatti100 (Aircraft I have modelled)
Inflation Option: Smooth Transition
Transition Ratio: 0.272
Maximum Layers: 3
Growth Rate: 1
Inflation Algorithm: Pre
Assembly Meshing
Method: None
Patch Conforming Options
Triangle Surface Mesher: Program Controlled
Advanced
Shape Checking: CFD
Element Midside Nodes: Dropped
Straight Sided Elements: [Blank]
Number of Retries: 0
Extra Retries for Assembly: Yes
Rigid Body Behaviour: Dimensionally Reduced
Mesh Morphing: Disabled
Defeaturing
Pinch Tolerance: Default (1.8mm)
Generate Pinch on Refresh: No
Automatic Mesh Based on Defeaturing: On
Defeaturing Tolerance: Default (1mm)
Statistics:
Nodes: 628473
Elements: 3430625
The error message I currently get is:-
Inflation Created Stairstep Mesh at Some Locations
Any help on refining my settings to obtain a mesh that is suitable for analysis is much appreciated.
GusRus is offline   Reply With Quote
Finding Lift/Drag/Moment Coefficients on 3D model aircraft EVBUCF OpenFOAM Running, Solving & CFD 12 August 7, 2013 17:22
Can fluent model aircraft icing promble? Doris FLUENT 14 December 22, 2012 05:16
[ANSYS Meshing] 3D Meshing for CFD analysis of aircraft nauman55 ANSYS Meshing & Geometry 0 July 25, 2012 15:15
setting up premixed model for NOx analysis perdita FLUENT 0 November 23, 2010 10:15
Aircraft model? Jason FLUENT 0 December 7, 2004 14:59
