February 16, 2015, 10:09 |
Cell size
Aberdeenshire
Rep Power: 11 |
Hi all,
I am using fluent for my project and it's been very challenging as I am learning it myself with no one to guide me. I have done my meshing using edge sizing and mapped face. I would like to know my cell size to enable me choose a good time step. Does anyone know how to get this info? Thanks |
February 16, 2015, 10:17 |
Lucky
Rep Power: 66 |
You always need small enough cells to get spatially resolved information but if you want time-resolved simulations, then calculate your cell Courant number based on the time-step size that you want and expected cell velocity. Target Courant number ~1.
February 16, 2015, 13:08 |
Aberdeenshire
Rep Power: 11 |
Thanks LuckyTran.
I finally set up my problem and monitor. I used a UDF to define my sinusoidal velocity. However, in the monitor at the inlet I get something like this velocity monitor.JPG I expected a sine profile but the above profile is only correct form wt = 0 - pi. I'm posibly doing something wrong. Could someone kindly point me to the right direction. Thanks. |
February 16, 2015, 14:42 |
Lucky
Rep Power: 66 |
Are you specifying the profile using magnitude and direction or components. I think you should be using x,y,z components.
February 16, 2015, 16:28 |
Aberdeenshire
Rep Power: 11 |
I initially used magnitude and direction. I have now used components and hooked my udf in the inlet x component. I have also monitored the x component velocity close to the outlet and I can see a sine behaviour.
Thanks again luckyTran. |
cell size, fluent, unsteady flow |
Cell Reynolds Number | laliong | Main CFD Forum | 12 | September 17, 2019 04:18 |
Lagrangian particle tracking and cell size | Julian K. | CFX | 4 | May 27, 2014 12:35 |
[ANSYS Meshing] Definition of cell size in icem | fender26 | ANSYS Meshing & Geometry | 0 | April 4, 2014 02:08 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
cell size | Baskar | Siemens | 4 | January 18, 2006 14:34 |
