Altering AoA causing 'Reverse Flow'?
Old   February 15, 2015, 00:23
Default Altering AoA causing 'Reverse Flow'?
Mark
woodmark75 is on a distinguished road
Hi I'm simulating a 3D wing in Fluent & am attempting to alter the Angle of Attack.
In order to save me remeshing each time (not enough experience/knowledge to use batch files), I've changed the inlet velocity to 'Components'. Then using trig (x=cos*alpha*velocity & y=sin*alpha*velocity).
The issue is that I get 'Reversed Flow' when I run the calculation?find anyt
I've searched the net to find a tutorial but can't hing detailed. Is this method correct & if so why is the flow reversing?? Thanks...
woodmark75 is offline   Reply With Quote
aoa, fluent, reversed flow
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
flow at 15 deg. AoA over a duct - 3D case sandy_1982 CFX 6 February 28, 2013 17:46
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 16:05
Simulating flow past airfoil with different AOA Quarkz Main CFD Forum 2 January 6, 2006 11:56
