problem with periodic BC in ansys fluent
Old   February 8, 2015, 09:32
Default problem with periodic BC in ansys fluent
joseph
josephmp is on a distinguished road
hi friends, when i applied periodic BC at the inlet and outlet of a 2D unitcell of a microchannel with specified mass flow rate, i got a seemingly unphysical pressure variation along the centre line with negative pressure towards the downstream end. But when i avoid the periodic BC and arrange unitcells in series with velocity inlet and pressure outlet BCs i get finite pressure drop. Why the periodic BC is not working? why the negative pressure? can you help me to solve this problem...?
josephmp is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Problem in sampling data of custom field function in ANSYS FLUENT v14 apek_great ANSYS 1 February 26, 2014 06:10
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 18:00
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
