February 7, 2015, 04:40 |
3D Rotating Cylinder Boundary Conditions
Ghady Deeb
Rep Power: 11 |
My case is very simple and straight forward. I Have a can (Cylinder) in 3D that is rotating filled with soda and I want to plot the velocity distribution inside the can. I have 2 Names selections: Wall and Top Wall (Shown in the figure below) The problem is: In Boundary Conditions, I am putting both Wall and Top Wall Rotating (for the same Rotating-Axis Direction and same angular speed). And I have wrong results. I think fluent didn't understand what I want, which is a simple cylinder rotating around its fixed axis. Any help? Thanks a lot |
February 7, 2015, 11:15 |
Cees Haringa
Can you elaborate in what way your results are wrong? |
February 7, 2015, 15:21 |
Rick
Rep Power: 26 |
Moreover I think that you should setup a single reference frame or moving mesh simulation..but you should obtain correct/similar results by assigning only rotational velocity to walls. Check your bc carefully!
Google is your friend and the same for the search button! |
February 8, 2015, 10:49 |
Rick
Rep Power: 26 |
I did a test; for the moving mesh case take care to the timestep!
http://www.cfd-online.com/Forums/mai...ving-mesh.html
Google is your friend and the same for the search button! Last edited by ghost82; February 10, 2015 at 08:08. |
February 8, 2015, 12:35 |
Ghady Deeb
Rep Power: 11 |
Thanks a lot guys.
Ghost 82, a big thanks. I need your help please since you did the same simulation; My problem description now is: 0) Rotating can (diameter=6.6 cm; height=0.2 cm; angular velocity=10 rad/s) 1) Steady, Energy Equation Off (Just want to plot the velocity); 2) I'm using in the BC the following:Rotational Walls (with angular speed = 10),and the Rotational Top Wall.Origin axis (0 0 0) and Direction axis (1 0 0) for Wall and Top Wall; 3) In the Cell Zone Condition: I selected the material inside the can which is soda, and The Mesh and frame Motion always not checked. 4) Velocity Initialization with V(z)= 0.33 m/s 5) First when I selected calculate, it rapidly finish the calculation (Almost 2 seconds) which I am sure that this is wrong. Plus on the Line (shown in Fig. below), the velocity distribution is always equal to 0.33 m/s. But on the face of the Wall I have the right distribution for the Velocity (Linear Distribution). I think my problem is major problem, but I can't see where. Thanks a lot, for your help and support. |
February 8, 2015, 13:25 |
Rick
Rep Power: 26 |
How many iterations did you set? What are your convergence criteria?
February 18, 2015, 08:15 |
Ghady Deeb
Rep Power: 11 |
Thanks Guys, it worked.
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[GAMBIT] Question about Boundary Conditions with mobile cylinder involved | samolcue | ANSYS Meshing & Geometry | 9 | June 26, 2012 03:11 |
CFX does not continue | Shafiul | CFX | 10 | February 17, 2011 07:57 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
