FLUENT animation from TUI Journal File
Old   February 6, 2015, 11:51
Default FLUENT animation from TUI Journal File
Jacob
smartsoldier is on a distinguished road
I have a transient simulation and I would like to create an animation of vorticity per time step. Using the gui I can easily set up the parameters under "Solution Animations" and then once it is finished I can write to an mpeg. However, I am now running in batch mode on a CPU cluster and need to use the journal file and TUI commands to get the job done. Does anyone have experience with this?
smartsoldier is offline   Reply With Quote
Old   February 7, 2015, 07:14
Julian Vogel
TEScientist is on a distinguished road
I always do animations by writing single images from dat files with TUI commands in a journal file using a loop. Then I create a video file from the images with matlab.
TEScientist is offline   Reply With Quote
Old   February 25, 2015, 08:26
fanch33 is on a distinguished road
Maybe it's too late but you can use the following command :
solve/animate/define/define-monitor and set the parameters you want.
It will do the same as what you know in the GUI.
Fanch
fanch33 is offline   Reply With Quote
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 06:26
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
