What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? |
January 30, 2015, 00:32 |
Nikesh Bhattarai
Rep Power: 14 |
I'm trying to simulate flow through a regulator to check the position at which the outlet pressure is 1,000 psi. (Case similar to the Fig. attached). The inlet pressure (static) is 2,800 psi. I can measure experimentally the static pressure using a pressure gauge before and aft of the regulator. But I don't have any velocity information.
I'm trying to perform this in step-wise manner by varying the position of the poppet-valve. But I have problems with BC. Fluent uses "Total pressure" while implementing "Pressure-inlet" BC and "Static pressure" for "Pressure-inlet". Since I don't know the total pressure at the inlet and also have no velocity information, what BC is better for my case and how can I proceed? |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 03:07 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 01:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
