solution convergence and mesh density in k-omega model (FLUENT)
Old   January 29, 2015, 18:09
Default solution convergence and mesh density in k-omega model (FLUENT)
ripong
ripong is on a distinguished road
I am running k-omega model with low Reynolds number correction using FLUENT. My 3-D geometry looks like a tree with multiple inlets with a single outlet. The Reynolds number at the outlet tube (it is maximum there) is ~13000 and at inlet tubes are ~500.
After running it for thousands of iterations, residuals for mass convergence and xyz velocities reached close to 1e-6 and started fluctuating in that range. But residuals for k and omega values do not decrease less than 1e-5.
My questions are
1. Is it alright to apply more stringent convergence rules for mass and xyz velocities and more lenient for the k and omega values?
2. What are the residual values "generally accepted" for solution convergence for each quantities?
3. I decreased the mesh density and the solution converged better (i.e., residuals reached lower level). Is this alright to trust the coarse mesh solution than the finer one? Both look similar except for small structures appear in the highest velocity domain in the finer mesh solution. I wonder if this is real or an artifact. How should I verify?
Thank you!!
ripong is offline   Reply With Quote
convergence problem, k-omega model, mesh density
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
