January 28, 2015, 10:28 |
Normalize contour on cut-plane
Rep Power: 14 |
When I plot the mass flow on a cut-plane by using local range, could it be possible that I can plot the normalized contour value on the plane (mass flow local/mass flow Max)?
Thanks! |
January 29, 2015, 08:46 |
Rep Power: 16 |
I guess you can have a "custom field function" as the normalized mass flow and then plot this new field function.
View with cut plane | Mudblood | FLUENT | 5 | April 4, 2020 11:17 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[ANSYS Meshing] Cut Plane Problem | cfdizzle | ANSYS Meshing & Geometry | 0 | December 4, 2014 16:54 |
Creating Contour Plots on a Rotated plane | maalaniz | FLUENT | 0 | August 22, 2014 21:14 |
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position | zhoubinwx | ParaView | 3 | February 13, 2008 05:46 |
