weight of air in cylinder
Old   January 20, 2015, 10:25
Default weight of air in cylinder
maczaj is on a distinguished road
I'm trying to simulate a injection of fuel to cylinder
filled with air.
I defined air as ideal gas.
Temperature, pressure of air and volume of cylinder is
known.
Where to check what's the weight of air in cylinder? (in
grams)
Can fluent calculate it?
Thank you in advance for your answers.
Best regards.
maczaj is offline   Reply With Quote
Old   January 20, 2015, 11:16
philus is on a distinguished road
Go to results->reports->mass
philus is offline   Reply With Quote
Old   January 21, 2015, 15:46
Thank you Philus
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR Carl CFX 1 September 25, 2006 10:48
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
