January 19, 2015, 07:09 |
Understanding of .cas and .dat file...:(
Rep Power: 13 |
HI,
I need to know about the formats of fluent cas and dat files(Solution files). When I referred to the fluent user guide, it has given only the grid size , data field and residuals format. But in my case I need to get shear stress values, pressure values, and density at each points..I'm unable to get these values from case and data file.. How to get these values at all the points on the boundary as well as inside the domain?? Any help would be appreciated.. |
January 20, 2015, 04:08 |
Rep Power: 11 |
How do you "need to get"? You need to read it in another program? Use "File->Export" for that. If you need to recycle in another simulation (same geometry, but different mesh works also) use "File->interpolate"
January 20, 2015, 05:14 |
Rep Power: 13 |
Thanks for the reply...
I got it from the FILE --> Export.. |
Pointwise segment file or .dat file example | RuiVO | Pointwise & Gridgen | 5 | November 23, 2015 11:46 |
Improper data to cluster through .cas and .dat files | kaeran | FLUENT | 0 | October 24, 2014 05:10 |
Reading a fluent data file (.dat) using another application | debanjanmukh | FLUENT | 1 | February 14, 2014 13:57 |
Is it possible and how to transfert .dat file into another .cas file | Joven | FLUENT | 2 | November 17, 2011 11:28 |
ACCESS VIOLATION error opening a .dat file | DavidSF | FLUENT | 12 | April 8, 2005 16:37 |
