Modelisation of a pipe: Segmentation fault
Old   January 18, 2015, 05:24
Default Modelisation of a pipe: Segmentation fault
Alexandre007 is on a distinguished road
Good morning,
Version: Ansys 5.0.7 (Legal education version)
I'm trying to modelise a simple pipe but when I want to made an "Hybrid Initialization" or run calculation this message appear:
"Received a fatal signal (Segmentation fault)".
After search on the forum I have seen that could come from a variable bad called. But I'm not programming.
The way I have already tested:
-> Directory's name too long.
-> No effect when I put it direct on the C:
-> My model (k-w) bad conditionned
-> No effect when I choose an other model (k-e)
-> Boundary inlet velocity bad conditionned in the "turbulance"
-> Choose "Specification Metod "Intensity and hydraulic Diameter""
-> Turbulence intensity 3.5 % (from the formul given :http://www.cfd-online.com/Wiki/Turbulence_intensity
( with Dh=0.1m and v=2m/s and Re=2e6)
-> No effect
-> I have some warning but I don't know if it could be a problem:
"Warning: Flow boundary zone 9 is adjacent to a solid zone (7). This problem MUST be fixed befor the solution can proceed"
For this other things I hope this not come from:
-> Outlet : Pressure
-> First layer 5e-5 m
-> It's the first time I try a calculation on Fluent
Thanks for your time,
Alexandre
Alexandre007 is offline   Reply With Quote
Old   January 18, 2015, 11:24
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Probably you defined the zone as solid and not as fluid.
So change from solid to fluid and it should work.
Daniele
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   January 18, 2015, 12:35
Default Problem resolved
It's the solution. Now it's work,
Thanks a lot,
Alexandre
segmentation fault
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
