January 13, 2015, 21:43 |
multi-machine parallel for Fluent 14.5
XH
Rep Power: 12 |
Hello everyone,
I have focused on the muti-machine parallel for fluent 14.5 these days. And there is always a problem. The relative works have been done. But after opening the fluent in the host computer, the state will always get stuck at this step"checking the status of SMPD for INTEL MPI on the local machine...smpd runing on tan-PC". And I also check the task manager seperately in the host computer and node computer. The corresponding cores have been working, and the process of smpd also appears in the task manager. I don't know what problems it has. And I've tried every method I could think, while they don't work. Could you please help me to find another way to figure it out? Thank you very much for your kindly help! |
fluent 14.5, multi-machine, parallel |
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines | ghost82 | FLUENT | 54 | February 9, 2022 04:32 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu | abhinav2601 | OpenFOAM Meshing & Mesh Conversion | 1 | January 26, 2015 06:42 |
Distributed Parallel on dual core remote machine | Justin | CFX | 1 | February 3, 2008 18:23 |
CFX-5.7.1(Linux) Parallel - 4 CPU Machine | James Date | CFX | 6 | June 14, 2005 19:03 |
