Problem: Convergent- Divergent Nozzle Venting to Atmosphere |
January 12, 2015, 08:57 |
Hi Everyone
This problem is regarding flow through a C-D nozzle. The geometry that is being used is in the attached image. The nozzle is usually given "Pressure Inlet" & "Pressure Outlet" boundary conditions. However, when considering a case where the nozzle flow is allowed to exit into an ambient fluid, what are the boundary conditions that might be required. Could "Pressure far-field" be used in the external region. I have tried using it and am presented with quite a few errors. Are there any alternatives that I have not tried yet? Domain Image : http://i.imgur.com/CfW0tEX.jpg |
January 12, 2015, 14:44 |
Rami Dalf
Rep Power: 11 |
You have a a closed volume and there is air under pressure. So, zero pressure condition did not work? Basicly it is only condition you have, pressure = atmospheric pressure at the outlet.
January 13, 2015, 19:57 |
Rami Dalf
Rep Power: 11 |
The set up itself looks very simple. If you want you can send it to me and I will run on my mashine.
boundary conditions, c-d, c-d nozzle, fluent, over expansion |
Rocket Nozzle problem | Jeremie | FLUENT | 10 | October 8, 2014 07:16 |
For Nozzle fluent problem | Jie | FLUENT | 17 | January 11, 2012 14:44 |
Convergent nozzle and preesure of steam | pranabjyoti | CFX | 7 | March 10, 2011 20:23 |
Nozzle flow problem | prabhu | CFX | 2 | March 10, 2007 08:38 |
Convergence Problem Supersonic Flow Laval Nozzle | Tobias | CFX | 3 | December 7, 2005 02:23 |
