Transfer of data from one simulation to another.
Old   January 1, 2015, 00:36
Default Transfer of data from one simulation to another.
Gomatam Sreekar
sreekargomatam is on a distinguished road
I have two simulations running, Simulation A and Simulation B. Is it possible to extract data for a particular zone in simulation A and use it in simulation B given the mesh, domain and boundary conditions remain the same? Also, can the same be done if the mesh size in A and B vary, by interpolation.
Thanks in advance.
sreekargomatam is offline   Reply With Quote
Old   January 1, 2015, 10:22
nuha
miss chemical is on a distinguished road
If you use Ansys FLUENT you can duplicate your simulation by right click on your work cells in workbench window
good luck
miss chemical is offline   Reply With Quote
Old   January 1, 2015, 12:23
Lucky
In GUI, for SimA go to file => interpolate. choose write data and select the fields you want to export. Then for SimB go file=> interpolate again but choose read and interpolate and choose the file that you saved earlier.
The TUI commands is /file/interpolate/write-data
As far as I know, FLUENT uses 0D (nearest neighbor interpolation).
fluent, fluent 14.0, initialise, multiphase flow
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 10:37
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 07:33
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Is it realistic simulation? (Heat Transfer Simulation) fshak92 STAR-CCM+ 5 May 29, 2012 08:00
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
