December 30, 2014, 14:50 |
pressure viscous drag on pipe
Hossam Alaa
Rep Power: 12 |
Hello every body, I am new Fluent user and I have a question on pressure and viscous drag resulting from flow inside a pipe with fixed area which should be:
pressure drag=0 , viscous drag > 0 in case of viscous flow .... when I used (hexahedron mesh) I found pressure drag =0, and viscous drag>0... BUT when I used (tetrahedron mesh) pressure drag was big value comparable to the viscous drag. can any one explain why this occurs when using tetrahedron elements?? Last edited by Hossam Alaa; December 31, 2014 at 04:33. |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Pressure drop across pipe | mnolan93 | FLUENT | 1 | December 15, 2014 08:26 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
About UDF for pressure Drag | mkrao | FLUENT | 2 | February 8, 2009 06:51 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 06:05 |
