trying to find the center of pressure of stratosail |
December 30, 2014, 12:17 |
Rep Power: 12 |
Hi guys,
I want to calculate the center of pressure of a stratosail body at different angles of attack. I have read through some of the posts, but I cant seem to get a clear step by step guide on this. Is it possible to print the coordinates of the centre of pressure? I have tried setting x=0 and then printing the other 2 coordinates. But, I do not understand this method. Alternatively, how can I calculate the moment due to the resultant drag force about the center of mass? The manual says that you will need a moment center and a moment axis. I guess the moment center will be the center of mass of the sail. But, why do you need a moment axis? Rgds Jay |
December 30, 2014, 15:20 |
#2 | |
Lucky
Rep Power: 66 |
If the center is at the origin. Your moment axis could still be any axis, (x,y,z, or any other axis). You must also specify what is the axis with respect to which you are going to define your moment. In other words, you need a point (a location) and a direction vector to define the axis and only after that is fully defined can you consider any moment. |
December 31, 2014, 06:58 |
#3 | |
Rep Power: 12 |
What about printing the coordinates of the center of pressure? What are the steps for that? Rgds Jay |
January 2, 2015, 07:37 |
#4 | |
Rep Power: 12 |
Rgds Jay |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
How to find the coordinates of center of pressure | Alexey | Siemens | 0 | February 1, 2007 11:37 |
Center of Pressure | Astrid | CFX | 0 | December 21, 2006 05:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
