Error
Old   December 30, 2014, 04:46
Default Error
Navaneetha Kannan
navaneeaero is on a distinguished road
Hi everyone
I am trying to Flapping wing analysis. I got "Error: error divergence detected in amg solver temperature" and then suddenly the lift coefficient changed to high value . Could please anyone help me to rectify this problem .
Thanks in advance
navaneeaero is offline   Reply With Quote
Old   December 30, 2014, 15:15
Lucky
It is a general divergence error, meaning that your numerical solution diverged. It is closely related to its sibling, the floating point error exception. There are sooo many reasons why that happen.
When does the divergence occur? On the 1st iteration, after a few iterations (say 10, 30, or 100 iterations) or randomly after 10 000 iterations? Most commonly, divergence occurs early in the simulation because of general problems with the setup:
Run the check mesh and check case utilities. Is your mesh of sufficiently good quality? Are there skewed cells? Skewed cells will cause numerical instabilities.
Are your boundary conditions consistent? Setting the wrong boundary conditions will inevitably cause numerical issues to arise.
Is your initial guess, initialization, good enough? A horrible initial guess is also error prone.
You can try reducing the under-relaxation factors a bit to see if you still run into divergence.
error
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
